Hi,
Just got this module & after 1st plug in it seems the clock input doesn't work.
Anyone have any familiarity/experience with this issue?
  • Have rate knob set to min (stopping internal clock).
  • Feeding clock/gate input to Bloom clock input (the one to the right of the rate input) from PAMs
Have contacted QB who said they'll look into it....
I'd try a factory reset.
- Put the module in global mode: hold channel button for 3 sec. until channel led is white.
- Then, hold shift + reset until leds flash.
- Hold channel button to go out of global mode.
My music on Bandcamp - Instagram - YouTube
-- geusensdriesmusic
Thanks, appreciate the response
I tired that & didn't work at 1st but when then changed the trigger on PAMs from gate to Triangle & bam, seems to be working using that ...
-- Traxam
Ok, cool. It was my first sequencer, got it about 4 years ago. Really nice module.
Resolution (in case anyone else comes across this same scenario)
When clocking using a gate from PAMs the gate width needs to be >1%
(Blooms gate trigger input needs 6ms 5V pulses or longer to register)
