Move [208] LTD Power Supply & Specs:
Total Power Output: +12v @ 1400mA, -12v @ 1400mA, and +5v @750mA
Dual bus boards deliver power for up to 26 modules using standard 16 pin, keyed power headers.
The power supplies use a single external 15V DC 4-5A 2.1mm barrel jack power adapter.
Move [208] LTD Specs:
Width: 528.5mm (208hp)
Number of Rows: 2
Available Depth for Modules: 70mm
Available Depth for Modules (above Power Supply): 62mm
20 Sliding Square Nuts Per Rail Supports Up To 40 Modules
80 (4-40 Size) Panel Screws Included
Guitar Amp Style Strap Handle
Side Mounted Secure Twist Latch
Removable Lid
8 Nickel Plated Steel Corners and Necessary Screws Included
Side Mounted On/Off Switch
Powered Bus Board supplies +12v / -12v / +5v
Dual Custom Powered Bus Boards with 32 Keyed Headers
Eurorack Bus Compatible Bus Boards
Side Mounted 2.1mm Universal Power Adapter Jack
15VAC 4-5A DC Power Adapter
Move [208] LTD Dimensions:
External Width including Latch and Hinges: 23.5"
External Depth including Handle: 12"
Height (including feet & lid): 7"
Height (including feet): 4"
Minimum Depth Available for Modules: 61mm
Maximum Depth Available for Modules: 74mm
