Knowing knobs height for your modules is crucial when designing a foldable case. Any chance this could be added in the module's stats?
I'd have though cable height would be more important... so you can leave it patched!
I personally don't leave things patched (or when I do I use Tendrils cables) as I like having a slimmer case but yes for some cable height is probably enough since most knobs aren't higher.
