Can you make it smaller? I only have 0.5hp free in my case.
-- sempervirent
ahaha I'll try! Maybe 1U also...
If this goes ahead as an actual PCB/Panel well colour me interested!
-- basicbasic
Well no pcb will be involved, it's just a panel with three switch! Maybe I'll do a small run of panel just to reduce cost. In case I'll update here!
Cheers!
Awesome - fingers crossed it goes ahead
There are two expanders for the Batumi - one is 3 hp and now another is 1 hp. I would build this but make it into a 2 hp strip. These odd numbers are a PITA.
DBL Post
TBH 2hp would be ideal for me too, but i'll take 1hp over 3hp in this instance :)
I've been having the same project on hold until I get my Batumi. Been in the planner since forever! 1hp is ideal. Colour me intersted, especially for the panel.
It's 1 hp first beacuse I need something to spare with a 3hp module (malekko noise) and then because I think that more than 1 hp to set 3 jumper would be a waste of space.
Of course I don't blame or critics xaoc for their technical choiches, but if I can made a module more close to my likes...why not?
Please if have suggestions write and I'll consider it! Think to do a run of panel in a month or so.
I'm interested in one of these as well. Thanks, dunk!
I'd definitely take one as well if you end up doing a panel run. Thanks!!!
Was there any movement on this? Did it happen!?
Hi,
can you make this 0.25hp, please?
x
______-.........-''
Really interested by this faceplate. Count me in.
What is the deal, is this still going ahead, has it happened already?
I need it to! Please take my money!!! :P
Where can I get this? Or at least the front panel?
