Hello guys. I want to build a modular rack to use primarily and initially as an FX chain. I would come out of DAW through the rack and back in to the DAW. Some distortion / filter etc FX in the chain.
My question is do I need the Audio Interface II module or could I go straight out of the DAW into the rack and back out?
Thanks
astrophonica.co.uk
Eurorack modules are capable of much higher output levels than line level gear. You can send eurorack signals directly into line level gear if you are very careful, but a mistake could damage the line level gear. It's a lot safer to have an interface module. Also, although line levels going into eurorack gear can't damage anything, the level does need to be boosted or it will be very quiet. I have the Audio Interface II and am quite happy with it.
