A little starter system, paired with a Keystep, that I suggested over here: https://www.facebook.com/groups/euroracksynthesizers/permalink/5101738319843796/?comment_id=5107993799218248 (screenshot: https://imgur.com/qSSy902)
get a bigger case - you will need it in the long term and buying a mantis now will be a better investment and remove the rack wart
do you really need an output module? probably not - replace with a quad cascading vca - veils for example - most will work as simple output modules - and this will allow you to modulate, for example, one channel of ochd with another - if you need headphone output then consider just a simple headphone out like alm hpo
spend the extra few $/€/£ on the fx aid xl - more modulation options!
personally I would swap the ochd out for a pamelas new workout
i'd also strongly consider links and kinks as they will add a lot of functionality for little cash in a small amount of space
my next module would be maths - work through the illustrated manual a few times - it's a great modular patching primer
Despite the fact that I have and use a Davolisint, I would never, EVER recommend a synth that has NO VCF. I even got a Waldorf 2-Pole for the Davoli, in fact!
The above build is missing so much stuff that my Davoli actually seems over-featured by comparison. Damn...
