Hi,
I know that exists clones of MI Elements also a little bit compact. Do u know something else about these? Do you say it can be worth it? Also in DIY will not a problem (I'm back from prok modules, nice experience).
Thanks
FB
If you consider DIYing it.. do yourself a favor and check the BOM first, a lot of Mutable clones have problems with chip availability
I don't know about the size etc - that's something that you'd have to work out for yourself - do you like trimmers instead of pots and poor ergonomics?
DIY is definitely possible - but I wouldn't recommend it as a first smd or even first mutable DIY
I would take a look at amazing synth and work out a path to building one and remember you'll also need a discovery board or similar to program it
However, I see that there are some pcba versions (smd pre-soldered) available - I would go for one of these - should be not much more difficult than the prok drum modules you have built already - it's probably just panel furniture and headers that need to be soldered and then calibration
Ok, thanks at all. What is BOM. Jim have u some links to share or a module name to search here? Thanks
edit: ok BOM intend the bill of materials... ok, i was actually referring to full diy kits for the elements. I miss the desire to make the shopping list.
what do you think of the Antumbra Atom? I have read that Plonk is also similar to Elements (obviously with its macro differences). So let me explain: I am assembling an auxiliary rack to my main one in which I have inserted effects modules, drums and I would like to insert a second complete synth module to always be controlled with beatstep pro since I have the possibility to manage two synths at the same time. Here the extra rack:
https://cdn.modulargrid.net/img/racks/modulargrid_1583445.jpg?1622279223
The Antumbra Atom looks cool and maybe if I had been very familiar with Elements I would have been happy with it. But I got the Atom first and I admit it was totally opaque to me. Sold it, got an original MI Elements instead. I think I might get along with something the size of Michigan Synth Works Quarks (https://www.modulargrid.net/e/michigan-synth-works-quarks-). The layout makes more sense and the knob size is a little more finger friendly.
yes, I think Atom is too tiny to control. Good idea Quarks, i didn't know it.
unobtainable, however, in Europe...
ah good you worked out BOM yourself!
personally I've got a full size elements on my DIY backlog - it's number 11 of 12 in order - making the shopping list is a lot easier than it appears to be and a useful skill to have in synth diy - it can reduce costs considerably in the long run - buy larger quantitites of common components etc
https://pushermanproductions.com/product/full-kit-antumbra-atom-v1-2/
but maybe available elsewhere
compared to elements, atom it costs half
it does indeed...
it's also half the size
but is it half as enjoyable to play with?
I agree. Maybe better quarks similar.
Could I combine a very compact voice synth like Erica voice pico with a Rings and more or less do the same things as the Elements?
