Hi, i have a Case :D
-> Doepfer Energy
Trigger Riot
TipTop SD, BD, CP, Hats (stereo okay)
Bismilus Iteritas
A-106-1 (stereo okay)
PoleZero SSF/WMD
Disting mk3
AD-Neuron
AD-Spectre
2x Malleko Mix
Okay...i have no consonance Stereo Out in my Headphones direct listening from
- Pole Zero (also if stereo from TipTop-SD, i have 95% mono left side here)
- Malekko Mix (both) ( 95% mono left side)
- Neuron ( 95% mono left side)
- Bisimilus ( 95% mono left side)
What happens here?
Energy Problems?
Headphones are okay, A-106 brings my stereo back...
Thanks for helping.
they sound broken, maybe you should sell them off cheap? id be interested
-- owbotic
no,. other ideas?
i only have anushri so far but am planning my rack similar to yours so had to try! I was of the impression that most euro modules and patch cable are mono, i.e. that is the norm, although there obviously some that do stereo, sometimes this would be on one minijack (tip/ring/sleeve) but more likely be separate monos for l+r. These are usually fx machine and have some kind of panning or width/spread adjustment.
what you need for head phones is mono to stereo converter jack, these come in 3.5>3.5 or 3.5>1/4
True,
Its not stereo, i understand now its Dual-Mono because Minijack-Construction.
My Headphones are Stereo. Some Modules have Dual Mono fem-Jacks.
But its dumb that the Mixers are not "Dual-Mono".
Sure i have only Params for Volume at it, but now i use the A-106 as a Mixer...with less capacities...
Later i will add Fx and....
How i can know, Moduls have Dual Mono if i stick i stereo?
Regards
øøø
Oh its the wrong Thread :/...
i dont know how you would know when buying. BTW i have some modules FS including the Pittsburgh Modular Outs which does stereo headphone amp and dual mono for mono or stereo connection to a mixer
