New jam, using the new Dreadbox Disorder Fuzz & Filter pedal with my Rhodes as the lead, it's a bit longer this time but hopefully not boring.
This is the case I used:
Patch Notes
Voices:
- Rhodes MkII Stage 73 amped by Mutable Instruments Ears, using Dreadbox Disorder as Fuzz & Filter, run through Mimeophon as delay.
- Instruo Ts-L + Eowave Titan Oscillator into ST Modular Werner as bassline, sequenced by Doboz XIIO with filter cutoff modulated by expression pedal from ADDAC Floor Control.
- Calsynth Rangoon sequenced by S.I.G. doing counter melody, with decay modulated by Make Noise Pressure Points.
- Ensemble oscillator through Bizarre Jezebel Pkhia as background harmony, sequenced by Clank Chaos.
Drums:
- Erica Pico Drums as kick.
- Blue Noise through Patching Panda Punch v3 as high-hat, with decay modulated by Make Noise Pressure Points.
- White Noise through Takaab LPG as snare.
Modulation:
- Clank Chaos as clock divider, gate generator and random CV generator.
- Mutable Instruments Stages as envelope generator.
- Instruo Ochd as LFOs
Utilities:
- MIAx3 as attenuation, mixer, offset.
- Super Vcas as vca and mixer.
- joeSeggiola's Nearness as panning sub-mixer.
- Cosmotronic Cosmix as mixer, using Dreadbox Splash as send effect.
- Music Thing Startup as mixer and clock generator and divider.
I'm loving these Jamms in a box with all the additional camera work and detailed descriptions!
Keep it up.
