hello to all here, my first post in the forum;)=
as stated on modwiggler and as you know, the OFFSET function on the Metropolix works as this:
example pattern: active stages 1-2-3-4 with modulations -> OFFSET +2 -> active stages then 3-4-5-6
Wouldn't it make much more sense if the result is after OFFSET +2 -> active stages 3-4-1-2
which means, the starting point of your pattern has rotated 2 stages to the right but WITHIN your pattern,
so you can adjust it to other sequencers etc ?
As it is now, you lose your pattern or have to re-program it, but what's the point then with an OFFSET ?
(also it would be nice, if the modulation lanes like ACCUMULATOR, RATCHET, etc could be (CV-)rotated
seperately, without the stages, but that would be another thing)
