I build this to add a few basic effects to a Subsequent 37. Now is this pure genius or plain boring? I would love to expand on a LFO module but have no space left in the Doepfer LC.
There's no need to use 8 HP for a triple passive attenuator module. You could replace that with a similar module or even one with more functionality from another manufacturer that takes up less space and you'll have room for an LFO module.
well there's absolutely nothing in there that I'd put in - including the case
start with a bigger case - you'll probably want to expand from this once you've got it and having the space already available will save you buying another case... bigger cases are often better value per hp and have better power solutions - tiptop mantis is near perfect starter case - buy (or make from cardboard) blank panels to cover the unused space
as a multi-effect unit I'd want one with a screen so it's easy to work out what algo you have loaded - fx aid pro would be my choice... because if you decide that you want another multi-effect you can then buy another one - either the standard of the xl and if you set it up right you can use the pro as a reference for the algos on the others - 1st 32 algos on the pro match the 32 algos on the other modules...
I wouldn't buy b-company modules without comparing modules from other companies - ie don't just buy something because it's cheap... find the one that you actually want - spend a lot more time researching before you buy...
you'll probably want to amplify the sub37 so it's actually at modular levels for processing
you will want more modulation and utilities than you think - these will exponentially increase the flexibility of the rack - they take up space - back to get a bigger case!!!
something to consider is that in order for a modular designed as an effects processor to be worthwhile - it is a full blown modular synthesizer, with an external sound source replacing the vcos - everything else is identical...
@JimHowell1970
Thanks for your suggestions. I was aware that my tiny box loaded with uncool Behringer modules won't be regarded as the latest hip thing in this community. One thing I want to avoid is to expand to a full blown modular system so buying a bigger case is no option for me.
@adaris
I guess you are right. I'll swap the bulky 995 with a Doepfer A-138n and a Doepfer A-145-4.
This would make my little effects box even more mediocre. But if anybody can give me an advice how I can fill up the 8HP from the 995 with flashy modules that suit my desire (at least 3 attenuators and a flexible LFO to modulate the Z5000) I might follow these suggestions. Thanks!
-- Jockl
don't doepfer do a 4hp quad attenuator and a 4hp quad lfo? I just checked, yes to both - more utilitarian than flashy though
Hi,
An attenuator/attenuverter module would be a good option.
For example https://www.modulargrid.net/e/addac-system-addac218
Regarding LFO, Doepfer 145-4, they are 4 simple lfos without VC, but suitable for modulating.
If you want to go one step further, ochd https://www.modulargrid.net/e/divkid-ochd
Best regards,
That doepfer-lfo is a nice basic module.. one of the first I bought and still in my case.
there are loads of 4hp attenuverters out there.
Instead of that 914 behringer; check the doepfer a128.. smaller footprint but different frequencies.
