You can now find Vaemi among manufacturers on Modulargrid. To do this, click the Modules tab in the Eurorack category. You can search from the Manufacturer section.
Below is the link for easy access.
https://www.modulargrid.net/e/modules/browser?SearchName=&SearchVendor=1044
You can now add our modules to your cases.
@Vaemi if possible please ensure there is nothing missing in the power specs:
thank you!
@modular01 power specifications are exactly as written and written correctly. 5V is not used in the module you gave for example.
-- Vaemi
this "5V is not used" should be inserted as 0 mA
its impossible to distinguish between zero mA and missing information when you keep this field empty
thank you!
-- Vaemi
thank you!
-- modular01
hello, thank you for your attention. Also, thanks for the warning. We fixed the issue
-- Vaemi
youre welcome!
@modulargrid consider to add some kind of instruction to insert 0 in case a specific power line is not used
