Shift Register essentially stores the data in binary form, and it shifting the data in accordance with a clock signal reference. In fact, thanks to this feature, it is used for storing, adding, subtracting, multiplying, and dividing data in a computer. Multiplication and dividing are actually the results of the shifting process.
Shift Register is a module that is designed for Eurorack systems, and it can run between 0V-+5V. It runs with a clock signal. This way, all the data entered through data input is synchronized with the starting and ending times of the clock signal. This module is a dual and 4bit Shift Register module. It can be accepted as a 4-step sequencer. The jack on the module that types data is input.Even if you enter a CV signal or gate signal, the signal you will get from the outputs is a 5V gate signal. The first output, on the other hand, gives out exactly the same pattern you entered in the data signal, only a better-synced version with the clock,while synchronizing with the clock signal, it shifting the written pattern to another output as the clock arrives. In fact, as a result, when you enter 16-note clock signals, you get a 16-note delayed version of the pattern you typed from each output. If you use this module in the audio rate range, you can run it like an oscillator with clock signals that are hear able for human ears. In this way, while patching with square waves in Logic, you primarily get different phase degrees of the data (square wave) you entered.
You can visit our website for more information.
https://en.vaemi.net/product-page/shift-register-eurorack-diy-or-assembled
https://www.etsy.com/listing/1330789369/
https://reverb.com/item/62464281
https://www.modulargrid.net/e/vaemi-shift-register
