Vaemi's new module XFMR VCA, which is designed for Eurorack systems, introduces users to a transformer-based VCA design.
Turkey-based Vaemi (Volt Age Electronic Musical Instruments), which commercially produces synthesizers and electronic musical instruments, recently released its first module, the Osi-Op (through zero fm VCO), and quickly followed with other Eurorack modules such as Shift Register, R2R Ladder, Buffered Multiple, making a name for itself. Now, it has introduced and brought its users the new XFMR VCA module, which is handcrafted with high-quality, through-hole components and features an audio transformer in its output.
The XFMR VCA is a VCA with linear curves. It has two separate audio outputs, such as the classic Op-Amp and the Transformer Output feature that gives it its name. It is AC Coupled and designed specifically for audio signals, making it a VCA module that you would want to use at the end of your chain. You can use it to add saturation, harmonics, and EQ to your patches made with the Osi-Op and through zero fm techniques, or use it for a clean range if desired. This wide range of options will be loved and make you feel comfortable.
Additionally, the XFMR VCA has an expander that allows you to expand it up to 3 channels. With the expander, you can have two more exponential VCA channels, which you can use for frequency modulation of oscillators or in other places you need them.
In studios, preamplifiers are equipment that can properly raise the microphone or line signals level without distorting or adding noise to the sound. However, when recording analog synthesizers, we tend to lower the sound instead of raising it because they have very high outputs. At this point, we thought that one of the most important things that preamplifiers add to recordings, other than gain, is audio transformers.
The XFMR VCA also has an EQ stage. This will provide great flexibility when finalizing your last patch, especially in multi-channel patches, and will provide a more accurate and clean sound in live performances.
Vaemi aims to create systems that can comfortably be used in today's electronic music and popular synthesis techniques such as additive, FM, Formant, Subtractive synthesis, and will continue to shape and evolve with new module designs that will be released in the coming year.
Please visit our web site for more information www.vaemi.net
Click the link to watch XFMR VCA Demo Videos
  • Transformer and Op-Amp Output Stages
  • Linear VCA
  • 2 Audio Inputs
  • 2 CV Inputs
  • Saturation and Distortion
  • 3 Different Distortion Types
  • 3 Band EQ
  • Amplitude Modulation (AM)
  • AC Coupled
  • 2 Channel Exponential VCA Expander (coming soon)
Modulagrid Module Link:
https://www.modulargrid.net/e/vaemi-xfmr-vca
