Another LFO, this one from Cubusynth.
4 outputs, each with different rates (and changing available ranges by swapping capacitors).
Very simple build, would be a great first module. All surface mount pre-soldered.
Only has a triangle wave, which is a bit limiting. Also, I found that the peaks of each LFO were not quite in sync (see ‘scope traces during the demo) which isn’t perfect.
Overall a good kit.
Build
