I would like to make autonomous it modular, to synchronizer both sequencers, but I do not know how can it be done?
Who would have a simple idea?
Thank you in advance
A BPM Clock module such as ALM Pamela's Workout or ProModular Cloq can be used to keep all your sequencers in sync.
You may also benefit from a syncable LFO (i.e. A-145 or A-147) instead of the A-146 module (which is NOT syncable); this will allow you to (e.g.) reset filter sweeps at the beginning of each bar.
I would also invest in a clock divider and a clock sequencer (i.e. A-160 & A-161), both of which my be used to generate timing/sync events.
Thank you for your answer,Togodumnus, I would listen to your good advice, especially as I have the modules which you quote.
Good music, Philippe
