The same envelope sent out of Disting E3 twice but at (sometimes) different speeds as dictated by the Tempi. The other Disting in H8 mode controls the pitch of 2 analog oscillators: Mother 32 (Squ mode) and DixieII (Saw mode). The scope is important here to indicate changes to envelopes in real time.
Order of steps
i: TUNE THE OSCILLATORS in UNISEN (use FINE knob on DixieII, M32 set to 4th octave C)
ii. leave Disting H8 Z Knob CV Input unpatched at the beginning, and Cinnamon CV to 0%
1) Envelopes: Same,
Interval: Same,
Cinnamon: No Cutoff Modulation
VCA: Closed, full CV Depth
2) Envelopes: 2nd is Half speed on Tempi
Interval: Same,
Cinnmon: No Cutoff Modulation
VCA: Somewhat open, full CV Depth
3) Envelopes: 2nd is Half speed on Tempi
Interval: 3rds,
VCA: Halfway open, medium CV Depth
4) Envelopes: 1st is 2x speed, 2nd is 3x speed
Interval: 3rds,
Cinnamon: Cutoff Modulation introduced (depth @ 12:00)
VCA: 75% open, little CV Depth
5) Envelopes: 1st is 2x speed, 2nd is 3x speed
Interval: Unisen,
Cinnamon: 20% reso, Cutoff Max, Cutoff CV Depth 1:30
VCA: 100% open, no CV Depth
6) Envelopes: 1st is 2x speed, 2nd is 3x speed
Interval: Modulated by Maths (plug it in, attenuated by Channel 2)
Cinnamon: 20% reso, Cutoff Max, Cutoff CV Depth @ 12:00
7) no more CV into Quad VCA
Envelopes: 1st is normal speed, 2nd is 2x speed
Cinnamon: Lower the cutoff
Maths: increase the depth of modulation, slow the Fall of Channel 1
8) VCA: Closed, 100% CV Depth and fade out
Octavian
Disting #1 Settings
E3 Dual AR Envelope
Z Knob: usually kept around 12:00
Otherwise default settings
Disting #2 Settings
H8 Dual Quantizer
Z Knob: Changes indicated above
Scale (Parameter 1 = 0, Major)
Input X Attenuation (Parameter 3 = 2)
Input Y Attenuation (Parameter 4 = -2)
Octavian
Tempi Settings
Clock Source: State Knob (none of the channels set the tempo)
Envelope Trigger Timings are listed above
Play around with Shift/Fine Increment or Fine Decrement tempo offsets
Octavian
Colour Scheme
M32 Out
- Red
Disting H8 Out
- Green
DixieII Out
- Blue
Quad VCA/Cinnamon Out
- Grey
Maths Out and Internal
- Orange
Tempi/Buff Mult Out
- Yellow
Disting E3/Scope Out
- Black
Octavian
https://1drv.ms/u/s!AsdkBRIREHjWirYrRPR_tXkI8VOVtQ
Octavian
