It can be if you're manually dragging the modules. But the other mode is quick and works like you'd want here. Hover the cursor over a module, then hit either "," or "." to move it left or right respectively. Even if you have a pile of little stuff in a row, this can be dealt with in seconds by using those shortcuts.
That's awesome. Those shortcuts should be added to the help page with the other keyboard shortcuts: https://www.modulargrid.net/e/forum/posts/index/2
Hi, just to express a feature request (already mentioned here https://www.modulargrid.net/e/forum/posts/index/11271 ): would be VERY helpful to have a global view of his own modules used (and how many) for all the racks. I'm talking about the modules in "My modules" tab.
To illustrate :
Before, I had a 15U monster case, but I was used to split it into several racks in Modulargrid - more manageable. And so it was difficult to know if I had put a module in several cases or conversely if I had forgotten one.
Now I decided to redistribute this big case in several smaller cases, and same issue : easy to lost track of modules.
I can see that this feature is not necessarily obvious to implement, but I'm sure there a way to address this need - even partially.
And of course I'm interested in possible workarounds used
humbly request an option to hide the clean up the mess cat or at least fix the CSS so it doesn't make the rack jump down in the viewport when the cat appears. a lot of us use that space as a staging area.
-- scragz
True dat...but I find the function that reorders "staged" modules into a single stack to be more annoying. There are reasons why I scatter 'em in various places while working out a build, especially reworking someone else's design.
As for ModularCat...you'd just better hope it didn't hear you complaining about it. You might log in one day to find clawmarks all over your module collection!
you're right I don't know what I was thinking. more cats fewer bugs!
-- scragz
Maybe they need a "bottom Draw" feature.
Just an area to dump modules without pissing off the cat :P
One feature i'd love to see is the ability to lock a position of a module or group a number of modules.
it would be awesome when you have to move your drum rack over 1hp :P
-- Keean
just add an extra row at the bottom of the rack...
3) links to deleted racks
its totally fine to get a 404 when trying to view a deleted rack.
but it would be nice to have all users public racks as a fallback
-- modular01
Starting with racks that are deleted today we have that now. You will be redirected to the users profile page.
