Anyone know which app I could use to help me use Grids to control DFAM?
I'd like to send a trigger to TR1 and have OC generate specific voltages at A, B, C and D to control some parameters of DFAM. Then send a trigger to TR2 and have OC generate a different set of voltages. I'm thinking I can kind of do this with Acid Curds but am looking for some other ideas.
Thanks,
Hoggarth
I have been experimenting with O_C and DFAM as well using the quantermain applet. Basically I had a trigger signal patched into TR1 and I set the scales of each of the 4 quantizers, set in turing machine mode to put out voltages that could modulate various DFAM parameters. The key I found is to tweak the octave setting to get an response from DFAM.
