NOTE TO SELF:
It appears Ripples can provide up to 14dB of gain. Maybe this can be used in combination with the 12dB of gain possible with Morphagene to amplify my recordings. I will have to verify Ripples actually provides this much gain. The manual says a gain of 5, which I assume is volts, which translates to about 14dB. I also wonder whether I can output a signal with just the gain and no filtering. This also frees up 2HP for another module or the Mutant Modular Preamp, which would provide all the gain I need, if that turns out to be really important.
I should also consider the WMD Overseer as an alternate to Three Sisters because it is a true stereo filter in 8HP. I could combine that with the Mutant Modular Preamp, but of course the recordings I bring into the system via the pre-amp would be mono.
