This is my Eurorack im slowly building up for Ambient(Dark Ambient)
https://cdn.modulargrid.net/img/racks/modulargrid_1182461.jpg
(Right now i use reverb and delay in the daw,when recording)
i might need some utilities,more modulators etc??
here's the actual link to the rack if anybody wants this instead of a crappy jpg
I'm not convinced you need more modulation - utilities to leverage what you already have would probably be less expensive and more effective = matrix mixer for starters
I would recommend rearranging your rack for easier workflow. Voices, filters, and VCAs together at the top, with sequencing, modulation, and utilities (envelopes, LFOs, etc.) on the bottom row. This will help you visualize audio and CV flow a little better. It may also help you see what you might be missing. Try to imagine how a MiniMoog's signal flow is arranged. That is a popular synth for its ease of use.
Have fun and good luck.
Also, unless you have a Clouds already, don't put it in here. Instead, use a third-party build...either a smaller version of the Clouds, or a more complex version such as a "Monsoon". farkas is also spot-on about the signal flow in this build...you'll have an easier time of this if you try and localize your audio path to one row, modulation to another, etc and make everything flow in the same general direction. Instead of the Minimoog, though, have a look at an ARP 2600 instead. I've always found it to be a superior teaching synth as well as an excellent workflow model for modular builders.
good points on the workflow re arranging,thanks
re clouds - if you don't already have it - don't buy a clone just now - wait for the mutable replacement - it will be soon!!!
must say,have heard to not get a clouds,as the sound is very obvioues
also have done some rearranging(the case im using is a tiptop audio Mantis actually thinking about getting another mantis,so i will have 4 rows
I think the sound of clouds is obvious if you use it in obvious ways - particularly running rings through it!!
also lots of people use it as an end of chain reverb
more interestingly you could load something into the buffer and use it as a vco!!
im interested in seeing the replacement mutable will come out with.personally i like the sound of clouds,
I like clouds too!!!
Even Rings into clouds from time to time
Emilie says there are 2 modules left for mutable - I'm more interested in the other module than clouds 2 (or whatever it will be called), especially if it is something new and not just a new (smaller) version of another module
sounds interesting,regarding matrix mixers,been watching some youtube videos,but abit unclear what brands to look into for those,my first thought is something not to expensive
AISynthesis
Doepfer
York Modular
all do inexpensive matrix mixers
I think it you want small go for the AISynthesis, if you want nice ergonomics go for the doepfer
AISynthesis
Doepfer
York Modular
think i will go for the AIsynthesis,also looking forward to testing the hermod sequencer with the E352 this coming weekend
Might want to check out happy nerdings 3xmia great value/hp.
just ordered theAI Synthesis matrix mixer today
Dark Ambient? Maybe consider Desmodus Versio instead of a clouds clone. Lots of potential there.
-- mowse
didnt knowabout that module deffo interesting thanks,put it on my to check list
Yup that is what I have tried to do in my setups for easier workflow- voices/filters/vca top row and tools/lfos bottom row.
I am so glad that I paid attention to the sage of experienced modular folks here like Lugia and Jim and bought support modules like Kinks/Links so powerful in complex patches. I have a Doepfer sequential switch and clock on the way to improve my setups. Then a matrix mixer and more tools like more attenuators and sequencer in rack future once budget allows. I found that I can use the support modules to make one voice sound so amazing and rich.
-- sacguy71
i have a matrix mixer on the way,i wonder what support modules would make most sense in this setup for Dark Ambient?
also one thing i would like to be able to do,is have the eurorack system be performance based,any tips on modules for that?
