I was wondering if a patch cable is wired tip-to-ring and ring-to-tip, would it reverse the polarity ?
Or is there a posibility of electronic malfunctioning?
thanks!
no
cables and jack sockets generally work with signal and ground
you'll send the hot signal to ground and the ground signal to where you are wanting the actual signal - which may or may not cause damage to your modules - you are free to try it at your own convenience!
if you want to reverse polarity use an inverter or polarizer module - this will take the signal and reverse the polarity
thanks!
NP!
