The description here says it "comes with" the TRS jack module, while the Intellijel site says it "connects to" it. I assume the Intellijel site is correct and the expander module is required, but it's not quite clear to me.
worshiptheglitch.com
That's correct, the trs panel is a separate purchase. This is because depending on your case, you may not need it. The 7u case has the trs jacks built in already. The 4u case does not.
I edited the MG entry to reflect the actual Intellijel description.
What happened to the photo? It used to be correct, but now the crop is wrong.
I’ll check with Danjel. I created the original images and had to add some extra blank space on the top and bottom for them to look right.
