So I have a Mother 32 and a Microbrute and I'm putting together a nice sidecar between the two. The goal is to use Reaktor Blocks along with the two units, sending CV from Reaktor thru ES-3 and into different patch points to modulate or trigger. The goal with the Shapeshifter is to have a digital sound source that I can run through the Moog or Microbrute or maybe even let it play on it's own and modulate the parameters through the various CV sources I have.
I think I have a "simple" yet versatile configuration here but would anyone have any suggestions or comments about the configuration?
ES-3 for routing LFO/EG CV from Reaktor into modules
Shapeshifter for a digital waveform source with tons of features (including delay and a vocoder)
24db filter for additional shaping
Multi for expanding the use of CV signals
Dual VCA (control via EG CV from Reaktor)
Stereo Out for sending the signal of the Shapeshifter directly into my UAD Apollo for recording if so desired
Another goal is to add one more 60HP rack to the Mother32 and expand into things like Clouds and Rings but that's a little further down the road.
