Hello, I'm curious to know if this module can work in reverse.
ie is it possible to send cv from eurorack through the A-177-2 to the expression pedal inputs found on some stompboxes?
I'd like to try this but I'm afraid I might damage the guitar pedal.
It's quite possible, but you don't need the A-177-2 for that. Just run a CV or mod signal directly from the source in the synth cab to the pedal's expression input. And if you're concerned about overvoltage, just run the signal through an attenuator first. In fact, running it through an attenuverter will allow you to rescale the expression range and even mess with inverse voltages (if the pedal can deal with them appropriately).
