Overview
First patch with the 2hp arp as it's focus.
AUDIO
Arp is driven with Metropolis for gates and root notes. Arp then dictates the pitch of the Demon Core Oscillator via an attenuation channel of Sinc Defero. DCO then comes out into Quad VCA (closed, enveloped from Maths), to divkid mutes, to hexmix as well as back out (mutes ch. 2) to the WMD/SSF Multimode Filter (MMF), that output of which is then fed back into mutes ch. 3 out to hexmix channel 2 (so unfiltered and filtered audio are sent in stereo to the hexmix).
SEQUENCING & Pitch
Pitch and Gate Sequences are sent from the Metropolis and distributed throughout the patch. 1 Octave range selected in config. with scale = minor pentatonic (PEnT-).
ARP uses Scale = Augmented 7th (2 LED's ON 3rd LED blinking) and Mode = Descending 2 octaves, with frequent but non-periodic changes in root note and arp reset placement
ENVELOPES/MODULATION
env1: While the Gate of Metropolis starts and stops the uneffected sequence, it goes to 2 places. First to ARP's Gate input, then to the TRIG input of Maths channel 1, to control the amp envelope on Quad VCA ch. 1, as well as the 1v/oct input on MMF. The envelope is generally kept with a short attack and medium decay, but later on in performance can switch to longer attack and short decay and blend in a looped delay track from Euro DDL for an interesting reverse tape-like effect.
env2: The other output from Metropolis that receives an envelope is the SYNC Out, which emits a gate at the beginning of each 9-stage sequence. Metropolis' SYNC is sent to Maths Ch. 4 TRIG input, attenuated out to ARP's MODE input.
lfo: slow free-running square wave LFO from M32 is sent to the Reset input, resetting the arpeggiation at repeating intervals that are unrelated to the Gate or Pitch sequences from Metropolis
random: Taking a clock from Metropolis, QuBit Nano Rand v2 in Magenta (Random Stepped Voltages) mode sends gate signals of various voltages to the Sync Trig input on DCO as well as an attenuated version to Maths CH. 1 BOTH input and an unattenuated version to Maths CH. 4 BOTH input. Nano Rand also sends noise into the FM CV on DCO and WMD/SSF MMF (Filter).
EFFECTS
Eventide Euro DDL is filtered and used looped or unlooped at different points in the sequence. Towards the end of a performance can create a "wash" of delay with maximum feedback. This sounds nice blended with the original signal where the original has a VCA/Filter envelope with a medium attack and very short decay, creating a faux tape loop effect.
Octavian
