Hey Nik_Neves,
There are sooooo many filters, so difficult to give you good and correct advice here. I might be wrong but perhaps the "taste" of which filter fits to a person is perhaps the most personal part of a modular system (besides of how the system has been setup). I made a list in Excel of the "first" 1600 Eurorack modules I found (I know there are thousands more here in the modules list, so you can have a look there too) and selected filters & VCFs in my list... I got more than 150 results... My favourites (don't have most of them yet):
(this list is not trying to be complete, just a few examples, between brackets is one of the main characteristics of the filter mentiond, by no means it conclude everything the filter can really do)
Doepfer A-106-5 SE (SEM type filter)
Doepfer A-120 (low pass)
Doepfer A-124 SE (Wasp)
2hp - Comb (Comb)
ADDAC - 702 (Dual VCF)
Bastl Instruments - Cinnamon (State Variable)
Befaco - BF-22 (Sallen Key)
Bubblesound Instruments - Diod (multi mode)
Dave Smith Instruments - DSM01 (Curtis)
Endorphin.es - Squawk Dirty To Me (multi mode, not released yet)
Erica Synths - Black Dual VCF (Dual VCF)
Grp Synthesizer - 12db SVF (State Variable Filter)
Happy Nerding - HN VCF (State Variable)
Instruo - Tràigh (transistor-ladder-low pass)
Intellijel - Polaris (multi mode & phaser)
Jomox - T-Rackonizer (Filter Matrix)
Kilpatrick Audio - K6501 Philter (Multi mode)
Manhattan Analog - Steiner Synthasystem VCF (Steiner)
Patching Panda - Vibrazum (multi bandpass)
Steady State Fate (SSF) - Stereo Dipole (quad multi mode)
Synthrotek - DIRT filter (low pass)
Toppobrillo - Multi filter (multi mode)
TouellSkouarn - Kala Goañv (wah/filter/overdrive)
WMD/SSF - PoleZero VCF (low pass MOSFET)
Xaoc Devices - Belgrad (Dual multi mode)
And there are so many more, please check here on modulargrid.net the modules and then select "filter" in the function field then you will find all those I haven't mentioned ;-) For the (correct) details of the above mentioned filters please refer to the manufacturers' websites.
At the end, the best thing is to make a selection of modules you are interested in and then check if your nearby dealer has them so you can test them
Regarding envelope generators, yes I think the Doepfer A-140-2 is a good choice, I went for the A-140 but's similar. It saves you 4 HP space too compared to the Quadra of Intellijel; naturally the Quadra can do things you can't do with the A-140-2; these are two (completely) different modules. At the end it's really what do you want to do with it? Depending on that you should decide on which EGs you are going to take.
Okay try this idea: Buy something seriously expensive for your wife (be it a diamond ring or whatever she always wanted to have), make sure it's so expensive that even she will feel a bit shamed of that fantastic gift, that should give you a green card for the next few years to buy whatever you want and keep reminding her onto that if the green card turns red. ;-) You might need to fine-tune this idea here and there a little bit but I guess you get my point :-)
Good luck with convincing your wife that you need a bigger system and kind regards,
Garfield.
