Metronomic form? A metronome is just a loudly-ticking clock with a variable speed. The problem isn't that at all...the problem here arises from using one timing device that has ONE internal standard (the metronome) vs. one which has a totally DIFFERENT one (Tempi, Pam's et al). Each device will think it's "right". Until/unless you opt for a single source as THE clock, and everything else has to use IT as a timing standard, this problem will reoccur.
Here's what's going on here, in a more traditional view...you have an orchestra with two conductors. They both know the score they're conducting in exactly the same way, but one of them is deriving the tempo from a clicktrack via headphones, and the other is relying on his internal timing senses, and the poor bastards in the orchestra aren't given any indication of which one is right. Different method, same mess.
