Hi Padmasan,
Are you sure that all those Behringer modules are nicely Eurorack compatible? Yes they fit into a Eurorack but how about the compatibility? I am not so sure and would check that first.
Behringer - Neutron is a great device but for other modules I would check other brands if I would be you, at least to start with. Consider a mixture of different brands to give you a few different ideas of what is possible.
If you insist on using Behringer modules then go to your local dealer and have it tested there first.
Good luck and kind regards, Garfield Modular.
