@nickgreenberg - if you include sequencers and mixers as utilities, which I do in this case - then you are probably spot on with my guideline
re audio outputs - depending on where you are in the world they may be completely unnecessary - I live in Europe where we have balanced mains power - so I have never used one - straight out to external mixer/speakers/es8 - always try without first unless you know you need a balanced output (not all outputs are balanced!) - start with nothing, then try attenuators (or vcas) and then finally try an output module.. no point planning to buy something you may not need, unless you do!
