too many sound sources in this size case imo
not enough support modules for those voices
not enough mixer channels to support all voices - I count 20 (the sound sources, mimeophon and beads) and only 7 mixer inputs - none of which are stereo (and both mimeophon and beads are stereo)
almost definitely not enough vcas - use them for modulation too
no offset, no inversion, no switches
no sub-mixer for mixing dixies outputs before filtering
I would want another filter - maybe 2
dump most of the bottom row, except for tetra, algoryhthm and maybe ears and maybe the i/o
buy a matrix mixer for mixing modulation
consider tesseract modular tex-mix as a end of chain mixer - inexpensive and expandable - I would suggest starting with 3 4mono channels and a 4 stereo channels and a master channel - 12 mono channels with vcas +4 stereo, 2 send/returns, cue/mix and headphones - all in 58hp for less than 400 of your choice of major currency
