Hey Modularfriends,
here's a update on the Skiff. Thank you again for your recommendations now, and when I started out:
Small DIY Kit Rewiew:
Frequency Central Seismograf SD (Snare Drum):
- Full Kit ordered from https://www.exploding-shed.com/
- Came with all parts and pre programmed snaredrum chip
- Build Guide is a litte rough around the edges, at the end I was not sure how in which direction the control PCB is connected with the main PCB. I did look up some builds on instagram to verify my setup
- Aluminum panel has nice sharp white screenprint but a little chipped at the side. No issue for me but might be from interest.
- I switched out the knured nuts for Befaco Bananuts, looks dope!
- Sound and functionality are top notch. Putting in an audio rate square wave in the gate input is lots of fun.
I might get a second one with the Kick Drum chip.
