The O&C isn't that menu-divey. Once you've selected a mode of operation, everything for that mode is on one page. The length of the menu might expand if you select certain features (like using a ADSR envelope rathe than a gate). But it's fairly simple to use.
neither are turing machines or distings
turing machine is pretty simple generate a string of random stepped voltages that are loopable - you almost always want a quantizer after it if you want 'musical'
disting is also quite simple - there's just a lot of it - it's just select algorithm and the knobs and i/o change but nto that much and it's pretty easy to get your head around especially if you set up favourites (a text file on an sd card) so that you are not trying every mode and having to read the manual all the time
As far as the turing machine, having a module that can send control voltage (like a Befaco Attenuverter or an Intellijel Quadratt) are nice for having better real time control of the Turing settings.
-- Ronin1973
@Ronin1973 hnmm - something wrong here did you mean scale and not send?
