Start with a dual filter, then. Something like the Intellijel Morgasmatron, which can work as a stereo VCF but which ALSO can work as two separate VCFs. You can also use this as a "mixer" to go from two sources to a post-filtered "sum" output. This is what I would suggest, as these filters have plenty of different modes as well as separate modulation paths...which, again, you can apply to BOTH filters if desired.
Thanks again for the advice, Lugia.
This sometimes feels like a hardware version of Magic: The Gathering. The longer you play, the more different cards/modules you know about. And there are a lot of them. Surprisingly the prices are about the same as well if you want the good stuff.
