Also, please take a second look at the case you are going to use. Since you've added a 104HP Palette Case Top Row, I assume you are going to buy an Intellijel Palette.
However, the Palette module you've added to the top row is only on the 4U Palette cases, which contradicts with your case settings that indicate a height of 7U. On the 7U version this top row is not present (although some I/O is on the back of the 7u Palette case), which would mean that you could remove that Top Row module, giving your case another 1U row.
You could also provide a link to the case you want to buy so me or someone else can create a valid ModularGrid template for you :)
