Wow thanks so much for taking the time to respond to my post.
No problem!
part of me thinks I should start very small so that I can learn my modules and figure out what I need
Yes and no. Yes - start with a small number of modules that will work together to give you a chance to learn how they interact. No - don't use a small starter case. Really, you'll be kicking yourself in a year (or sooner) if you start with a tiny case.
One other option I forgot to mention is that you'll get a lot of bang for your buck with a multi-utility or multi-function tool like Maths (worth the hp for all the versatility it brings), uOrnament and Crime, or Disting EX. The last two are a little menu-divey, but either will give you access to a large number of utilities and will allow you to figure out which ones you actually use.
Good luck!
