Gotta agree here...this is a little too 'undercooked' at this point. 'Take it slow' is wise advice, to which I would add 'look at other examples', which is another great asset of MG, although you need to be careful to check ones done by the numerous users on here who've got some experience rather than using random examples.
As for sequencing...for something rather tight on space, you might even consider going outboard, since sequencers are usually space-hungry things. Have a look-see at the KOMA Komplex; that, in combination with a Monome setup, would be downright scary.
External processors aren't a bad idea, either (would let you lose the Magneto and free up buttloads of hp!), but remember that the right way to use them, in most cases, is to employ some sort of send/return module(s) that step down the signal to the effect, then step its output back up to re-insert it into the modular's signal level. Also, not a bad idea having that 1U tile row there, but keep in mind that Intellijel's tile format locks out all of the other tile choices, whereas you can kindasorta fudge Intellijel tiles into the 'conventional' format with a little ingenuity (and a bit of hacksawing on the mounting holes on their tiles).
Hey thanks for the reply.
Why do you think its under cooked?
My approach is to keep it simple, not really into making new crazy sounds. Hence I would like to focus on making good melodies. Some might argue I wouldn't need to go Eurorack for this... and this is also what I have asked myself.
I will be sequencing with the grid and ansible. I think the pair can already do A LOT in terms of pattern creation along with shifty to create new melodic ideas. It can also do modulations on the fx processing side with the magneto & cloud working with the pamala's workout & chance. I'm planning to use the seq switch & T43 for different wave & octave variations.
I agree a LFO module would probably be good as what jburzy01 have suggested.
I'm planning to have some sort of sampler in there for live instrumental improvisation in the future.
