4 Moog Eurorack Cases 60 HP:
  • Stacked with 4 tier rack kit by moog
  • 0-Ctrl taken out of it's oiginal case and mounted into the rack
  • Hole for the original 0-Ctrl power cable connector drilled into the left side of the wooden cheek and metal side plate of the housing moog case, aswell through the rack stand frame
  • 2 4ms Row Power 45 as power supply attatched through a custom cut opening with screw holes in the lower back region of the 2 inner // middle moog cases (plugged into a smarthome power socket to turn on and off)
  • Using the 4ms Barrel Jumper Cable (angled) to combine // chain both power supplies
  • Using Eurorack Busboard Extender by PUNKmodular to extend each flying busboard into a chained second busboard cable
  • Extended flying busboard cables are routed up from case 3 to case 4 and down from case 2 to case 1
  • Metal side plates aswell as case sides are filed down at one spot for the extended flying busboard cables to be routed through to corresponding other case to give their modules power
4ms Pod40X (powered version) 40 HP:
  • Sitting to the right on my desk
  • I am not using the direct audio outputs of the ES-9 so its slightly shoved underneath a Keystep pro that is resting raised up on 2, 7cm high wooden blocks
-Reserved-
