does anyone know if the "ALM PAMELA'S NEW WORKOUT" module can be used on the same power bus to which a "MUTABLE YARNS INSTRUMENTS" is already connected?
thanks a lot for your help
All Eurorack modules use the same bus. If there's enough current from the power supply present on the supply rails to support both, then the answer would be yes.
