Overview
The modular system covers the Lead (Solo) and Bass lines for the arrangement.
The Lead Line is played by the Mother 32 and ES Disting mkIV set to algo B8 (VCO with Waveshaping)
The Bass Line is played by the DixieII and MI Plaits set to algo 1-1 (Pair of Classic Waveforms)
Gates and Pitches are sent from the Polyend SEQ both directly into the Mother 32 (for Lead voices) and into to Polyend Poly to be routed and multiplied later on.
The pitch tracking for the Lead Line is handled via MIDI directly into the M32's MIDI DIN Input, where as pitch tracking for the Bass Line is converted from MIDI to CV and sent to the second ES Disting mkIV H3 algo (Dual Quantizer) for added stability.
Both of the oscillators used in the Lead Line are filtered using the Ladder filter on the Mother 32 in Lowpass mode.
Both of the oscillators used in the Bass Line are mixed (1 source from Dixie and 2 sources from Plaits) and filtered using the Cinnamon filter in Lowpass mode.
There are envelopes for the Filter Cutoff and VCA CV for both the Lead Line and the Bass Line. The Filter & VCA Envelopes for the Lead Line are handled by MI Peaks set to Expert Mode so that there are 2 unique ADSR envelopes (Output A is for the Filter ENV; Output B is for the Amp ENV). The Filter Cutoff on the Mother 32 is manipulated by BOTH the Peaks Filter Envelope and the MIDI Velocities from the ASSIGN Out. These are sent to the internal VC MIX and the VC MIX CTRL is adjusted via the Keyboard Output on M32 and attenuated by Maths Channel 2. The Filter Envelope for the Bass Line is sent from the Unity Output of Maths Channel 1, where as the Amp Envelope for the Bass Line is sent from the Synthrotek ADSR.
MIDI Velocities were meticulously specified in the Polyend Poly for the Lead Line (as of March 31st, but might add velocities for the comping and Bass Line later on), and they are captured inside the M32 via the ASSIGN Output (set to Option#9: MIDI Velocity).
Mordax DATA is used extensively to monitor Oscillator tunings and Octave distributions.
Octavian
MIDI Routing
This patch represents my most complex MIDI Routing setup to date, involving the Quadra THRU and Quadra MERGE devices from MIDI Solutions.
Follow link for MIDI Routing Diagram
https://1drv.ms/u/s!AsdkBRIREHjWisl3dGNzTRA4pM9_Dg
Octavian
Colour Scheme
M32 - Green
Disting mkIV - Blue
DixieII - Red
Plaits - Yellow
Maths - Orange
Peaks - Grey
A MIX/Cinnamon - Purple
Polyend Poly/ADDAC200B - Black
Poly CH. 5 Pitch Output/Anything related to Moog Spectravox - Purple Stackcable
Octavian
Video: https://1drv.ms/v/s!AsdkBRIREHjWisldiJCsGL60ua-0dw
Octavian
Polyend SEQ Velocity Backup
https://1drv.ms/x/s!AsdkBRIREHjWish_EcmI2bzBPkfmvA
Octavian
Super cool!!
