Link works - thanks
There's quite a bit of duplication there
I would either get Marbles or Turing Machine/Clock Divider/Wobblebug/Quantizer - why? because Marbles does all these things - the only exception being processing audio - but you can use the random from Marbles to modulate the audio source instead - or if you desperately want to explore randomizing audio then get a wobblebug as well, later - so I'd get Marbles
I like to use a combination of Kinks, Links and Branches as utilties to expand Marbles (If you get one - get Kinks - you can get 7 related modulation outputs from a single source, with some self patching and stackcables) so I would get those next
I'd also add a Disting mk4 - as it's a great learning module, will show you the way to further modules, and will always be there to fill in when needed
I'd get a quad cascading vca instead of the matrix mixer (I'd get a matrix mixer too they are great - but in the future) - you may find very quickly you want a second one of these as they are so useful, for cv as well as audio - my pick here is Veils - it's simple to use and has a lot of gain available if needed
Then I would get Rings and Warps (and probably at least try parasites firmware on warps)
Then I would stop and see what else I needed - maybe follow disting - maybe a wogglebug NB if you want to use this for processing audio - you can't send the audio output through a quantizer to get it in tune (that's not how quantizers work) - it will just be what it is
Generative music normally requires a lot of plumbing (utility modules) and modulation - so you will probably want more of these - sequential switches, mixers, function generators, lfos, evelopes, lpgs, etc etc - for slowly evolving chaotic modulation the nlc triple sloth is hard to beat
As for cases - get a bigger one than you think you need - the tiptop Mantis is a great size and is usually the most economical case ($/hp) at the moment - behringer may change this with their larger case which is due soon, but the power may not be so good
