I don't know... I built mine (smd pre-soldered), but I'm sure Mangu's soldering is at least as good as mine, if you bought 'factory built'...
maybe my gain staging is better... maybe my hearing is worse (I'm 52, so possible)... maybe I don't run the output at a very high volume...
as I've said I only really notice bleed on the send/return - if channel send is up ad then I mute the channel - I can still hear the channel in the send - but this is to be expected when send is pre-mute!
