Thread: 2hp Mix
There is pretty much zero channel bleed and you have to have multiple signals turned up all the way befor the way before there is distortion. The distortion is pretty clean sounding and when observed on a scope looks like a straight clip. The 2hp mix also works really well with control voltages and the scaling on the knobs is quite smooth, without any big jumps in volume.
-- CryptoGreen
Oh, I interpreted "The 2hp Mix has superior channel bleed" as if it had major/significant channel bleed. Thanks for sorting that out :)
