It appears the developer has lost interest and the firmware may never see another update or feature enhancement? Since it's open source he has no profit motive to maintain it.
Advanced Step Sequencer (silver version)
https://westlicht.github.io/performer
-- mntbighker
if it's open source then anyone should be able to fork the firmware and maintain it/add features...
-- mntbighkerif it's open source then anyone should be able to fork the firmware and maintain it/add features...
The question remains if anyone ever will.
-- mntbighker
I volunteer you... you seem concerned about it... so maybe you should do it
I'm not a programmer.
-- mntbighker
you could learn, it's not rocket science - and the code's already written
I wish I had the time to learn to code, but simple as it may be, I don’t..
I'm a developer, and even if you have the knowledge, it is not an easy task to modify the code written by another, especially if that other person is the creator of the Hardware. Anyway, if it's a small change, don't be discouraged and get your hands on it.
It is difficult or even impossible to break the hardware through code. It is more dangerous to manipulate the hardware.
I am a programmer...
-- ferranadsr
me too...
I took a look at the code as well... it looks like a bit of effort to get into, but only because there's quite a lot of code... it doesn't look that difficult (clean code with meaningful names and nicely laid out) once you do and know the basics of programming/C++... in other words probably not much more effort than it would take either of us - or any other programmer, for that matter
all programmers weren't programmers before they became programmers - you have to start somewhere!
I suspect everyone using this forum has the basic skills needed - reading, googling, high school level maths and typing
here a custom firmware: https://github.com/mebitek/performer
here the improvments:
- Extend retrigger value. max 8 retriggers per step
- Extend probability steps. min value now is 6.3%
- add negative gate offset feature
- add metropolis style sequencer option
- double click to toggle gates when editing layers other than gate
- do not reset cv outputs when clock is stopped
- add various curves
- use random seed each access to random gen layer
- add curve improvements
- add midi improvements
- add noise reduction
- add track names
- add quick tie notes feature
- various bugfixes
- improve solo perform
- launchpad follow mode
- launchpad improve slide visulazation
- launchpad color theme
- launchpad circuit dstyle note editor
hope you can test it and reports bugs or feature requests on github
Electronic music/video producer and composer.
Dark Ambient Cinematic atmospheres from Sardinia.
new release!!! v0.1.48
https://github.com/mebitek/performer/releases/tag/0.1.48
as always, please open issues on github and share your experience with the custom firmware.
don't forget to rate the project to gitub!!!
enjoy
Hi all,
I proudly present version 0.2.0
https://github.com/mebitek/performer/releases/tag/0.2.0
you can find full documentation here:
https://mebitek.github.io/performer/manual/
as this releases contains lot of new features (over all the new stochastic track) please open issues on github. I will not implement new feature requests until the current 0.2.0 version is perfectly stable.
thx to testers:
Guillaume Libersat, Nik Ansell, XponentOne, Blueman Gil Arts, hales2488, Matteo Chiarenza Santini, KittenVillage, Andreas Hieninger
and thx to all who made donation or bought my music to support my work on the beautiful Westlicht PER|FORMER eurorack sequenceer
Version 0.2.2 is out:
https://github.com/mebitek/performer/releases/tag/0.2.2
Logic Track
fix shift steps feature -> Guillaume Libersat
step recorder "move step forward" shortcuts
step recorder "current step" cv routable, respond to gate (5ms)
curve track cv contrallable min and max
Overview page improvements
add trigger curve shape
add filter note parameter
thanks to the greatest tester team ever: Blueman Jil Arts Pompeius Magnus Lenneskog Andreas Hieninger
full documentation: https://mebitek.github.io/performer/manual/
feel free to open an issue on github to report bugs or open a discussion to share new ideas
remember to rate the project on github and if you want just make a donation to support my work
