If you go searching for "shift register" there are zero modules in the results. This must be some kind of glitch or MG just added shift register to module descriptions before manufactures had a change to use that tag?
All I know is I was searching for a specific SR and noticed nothing comes up under that "function." There are zero results.
Maybe someone at MG could fix this for us?
in the mean time you can always type shift register in the search field - that works!
I think that was recently added. You may be able to edit some of them and add the tag if you are bored.
