I've got a question about the usefulness of external MIDI controllers or even more capable devices like the Ableton Push with Eurorack.
Right now my setup is 100% modular only. I don't have a keyboard of any sort, and I don't have a DAW or a computer rigged up to my system either. I specifically don't want a PC involved, I use those enough througout the day and one of the things that I like about modular is that it's an escape from a computer. However, one of my main interests in synths is the fat polyphonic sound from a lot of the classic 80's synths like the CS-80. Even though I plan on building a large rack I forsee that at some point I'm going to want to dive into a non-modular synth like a Deckard's Dream, Ise-Nin, etc. The problem is those require MIDI to control. I do not want to use a traditional piano keyboard and I do not want to use a PC, laptop, etc. I have found modules to generate MIDI from CV but that seemed both complex and limited at the same time--more like it was useful for interacting with a synth setup, but rather limiting as the only interface.
The other day I stumbled across the Ableton Push III via a Youtube video. I have zero experience with these sorts of machines but it seems like something like this might be very useful to me. It is a MIDI controller that could play MIDI capable synths like the Deckard's Dream--via its buttons and also as a sequencer. It also functions as a synth on its own, which is attractive since I can use it to augment my modular setup--for example right now my modular system is very weak in the drum department, something like this could handle a lot of my drums before I get a chance to buy all that in modular. And finally, I understand the version III has 4 CV outputs, so it can be used as a modulation source too. Using something like this as the main controller for the external non-modular synth(s), perhaps augmented with MIDI generating modules as I can afford them, seems like a good way to go.
I'd appreciate any thoughts, also any suggestions for other hardware to take a look at.
