Rack DI Box for Gökhan Türkmen Stage
The Rack DI Box designed by VAEMI is specially crafted for Gökhan Türkmen’s stage performances. It can accommodate all digital or analog equipment, synthesizers, and drum machines, ranging from line-level devices to high-voltage synthesizer levels. This allows you to input the unbalanced audio signals of your equipment into the microphone preamp in a balanced manner through an XLR connector. The Rack DI Box is designed in a 2U rack format and features 8 channels.
Key features include:
- Balanced XLR Output
- Neutrik XLR connectors
- Enables the transmission of audio signals over long distances
- Clean and transparent sound
- 0 degree phase shift
- Accurate isolation from electrical noise in the audio signal
- -12dB Pad available for each channel
- 180 degree phase switch for each channel
- GND Lift switch for each channel
https://en.vaemi.net/rackdibox
