Here is my build.
As you can see it's pretty simple, built around Plaits and Clouds which looks like a good match.
¼" line outs to record with my interface and headphone out. (needed)
FX loop to use external pedals. (exchangeable if better function)
Pamela's to put everything to work.
Midi in because I can't find better use for 2hp left. I have some nice Midi controller apps and could also use Ableton or my Cosmic Music Box to trigger things. (exchangeable if better function)
I was also considering Ears by MI to use my guitar or synths with clouds but I think S.B.G can do that already, am I right?
I plan to fit this into a Doepfer A-100 LC1.
Any module/function I should consider changing or adding onto a bigger case?
Thanks in advance!
Looks like a lot of fun! Have you thought of a function generator, instead of Pamela's Workout? Something like "Function", or even "Mod Tools" might give you a bit more by way of modulation. I was always under the impression that Pamela's Workout was akin to a clock generator, not so much mod source -- just my understanding on it, though.
When I started building my rack(s), I based them on systems that were already existing, and I know Perfect Circuit has some small systems like this that might serve as a good template.
Keep it up!
