I recently bought a make noise monorocket 90hp case. It has a flying bus 16 pin cable connected to the board and 16pin female header pins. I also got Dixie 2+ that has a 10 pin power connector. So I was hoping to get some advice from you guys on the best way to connect the two.
• Can I get a Flying Bus cable with 16 PIN MALE header pins and then use the cables that are usually provided to with modules to connect everything.
• Would it be better to get a Flying Bus cable with 10 PIN FEMALE header pins?
• Are the two cables interchangeable on the Monorocket?
• Are there set voltages for Flying Bus cables? I noticed that the Flying Bus Cable that came with the Monorocket has 300V printed on it.
