Hello!
Im interested in having 4 LFO´s with the same 90 degrees out of sync. I need the rate to be between 2 and 10 minutes slow.
Im reasearching and maybe the XAOC Butami can do this, setting it to QUAD mode.
The manual says that negative voltage in the "frq/ph/div" CV input will allow an extended frequency range up to 53 minutes, but doesnt specify if all the LFO`s will react to this lowering of frequency, while mantaining the "90 degrees out of phase" relation of the QUAD mode . Maybe only LFO 1´s rate changes.
I email the the official site and havent got a clear response yet.
Anyone have one and now the anwser?
Is there another module that can do this?
thanks!
This: https://www.modulargrid.net/e/doepfer-a-143-9 And yes, you can get those sort of LFO rates in its "L" setting with the application of control voltage at CV1.
thanks!!
I have a Batumi and recommend the Poti expander. It really helps use the options for the module without dealing with changing jumper settings on the back of the module.
Phase and frequency in quad mode are preserved for the 4 lfo in slow speed mode.
